padraicR Feb 25, 2013 #1 Hi lads just needed to swap steering column shaft but when i take it out the ignition barrell is screwed down with two normal screws and two which i do not know how to remove :
frank Club Member Feb 25, 2013 #2 small chisel or centre punch, i usually bust a bit of the shrouding away first
OP OP padraicR Feb 25, 2013 #3 But they seemed to be screwed in ? From what i see from the bottom? And thanks for quick responce
frank Club Member Feb 25, 2013 #4 aye, they,re shearbolts, bust the red bit out and turn the head with the punch/chisel
