yesterday i changes a flat tyre and now when im changing gears the stick bangs from underneath the car it sounds like metal hitting off metal any ideas what this could be and how easy it is to correct as i would like to do it myself if possible it was the front drivers side wheel i changed if that helps any but i cant understand how that could affect the gears it drives ok still but bangs alot when the gear stick is moved about
