Hi, all. I've just registered on this forum and hope someone will be able to help with the following query.
The rubber boot or gaiter is split on the n/s/f lower suspension ball joint and I need to replace it to comply with MoT regs. However, I'm told that new gaiters are not available to buy separately, and the ball joint is not a separate item for post '98 cars and I will have to buy a complete lower arm with integral ball joint.
As there is no wear in this ball joint I don't want the expense & hassle of changing the lower suspension arm. So, can anyone help with a good secondhand undamaged ball joint gaiter which will see me through?
Many thanks.
Many thanks.
