CMF_Red Menace
» CMF MemberOK, here are the symptoms:
- Car developed a high (but smooth, I think) idle. Not sure of exact RPMs, but it was very high - 2000+. Only happened twice, with a hot engine.
- The second time, 3 days after the first, it happened in traffic, and the car overheated dramatically within two minutes. I got the car towed.
Based on high idle and overheating, I changed the head gasket, even though there was no sign of cross-contamination of oil and water. Then I flushed the cooling system - except in a moment of ludicrous stupidity, I flushed a breather hose by mistake and literally filled the engine. I've subsequently flushed it through with a lot of oil. I know, it was a stupid thing to do...
Thereafter, I queried the ECU, which said that the airflow meter is the cause. I've done the soldering fix (and, ominously, extracted a little water from the sealed circuit box in the process) but the idle remains rough.
These are the facts:
- Airflow system has been misreading at some point, either because it is faulty or because it is water damaged.
- Coolant temperature sensor is within limits - haven't tested the wiring back to the ECU, but the ECU doesn't complain.
- Engine overheated - shouldn't the fan have kept this under control? I switched the engine off just before the gauge hit the red, but it was rising very fast.
- Head gasket wasn't the problem, nor the thermostat, and the water pump is good.
If it wasn't for the overheating, I'd assume it was the throttle body as everything else points to it. If it wasn't for the ECU code saying AFM not coolant, plus the temp sensor reading OK on a voltmeter, I'd assume it was a bad temperature sensor, telling the engine it was at -40C, fuelling accordingly and refusing to turn on the fan.
I'm confused. I'm also obviously stupid for filling the breather with a hosepipe, but there's always one idiot.
