lol that hurt kev
ye the kit is quite thin, but mine feels realy rigid, and strong, the moulding itself on mine is good aswell, with fitting, the front bumper can be done on your own, you just drill two holes were the normal bumper has holes to screw into the arch (these holes are marked on the kit) then you fit it, and drill into the cross member and screw it in there, (thats what the fitter didnt do on mine and so it came off)
the rear bumper-theres two options, you can get your original bumper and cut out the recesed strip along it, (the bit that from the outside is a long strip that goes the length of the bumper, just below teh top) this has the mounts on that the kit doenst, so you then fiberglass that section to the inside of you kit, and then you have all the nescerary mounts,
the other option is- on the rear of the car, theres a lip, and then under theres a larg metal frame that goes across the rear of the car, you can get some metal and fill the first lip, braize/weld/fiberglass it into posistion, then fit the bumper, and drill through the bumper and first lip into the second, then screw the bumper in under the wings, fit screws into the holes you have just drilled, and if you can get nuts on the underside of the second lip you drilled through in order to make them secure,
the major problem with the kit was the delivery, as they couldnt be arsed with packaging properly, so i'd say go and collect, and then you can also see any issues with quality, and if there are some, you can say you think its to thin, or bad quality, and they can either sort it or you can walk away, then you wont make a loss
