Many manufacturers will say it's "Filled for life" when it comes to gearbox oil, and that it doesn't need changed be it auto or manual. Or if you are more cynical then you'd think they know the gearbox will give out at somewhere over 100k miles and most owners will buy a new car. So it's not in their interest for you to look after the gearbox oil.
If it's a proper automatic with torque converter then it's not so simple to change, much of the fluid will live in the converter if you simply drain it.
