Are K10 and K11 shocks interchangeable ?
Only the front shocks are interchangable, the rear suspention is a completely different set up on both cars.
Some modification is needed as the bracket for the brake pipe is in a different place, so it'll need bending.
The k11 shocks are a lot harder than the k10's so retrofitting 10 shocks onto an 11 may cause front end leaning if no ARB is fitted.
