Hi all,
Managed to find a good condition front bumper at the local breakers yard to replace the cracked one which mine had when I bought it.
Whilst I was doing the switch I had a look around to see if I could find the front fog light connectors. I found two that look like the right fit (pictures below). There was one on either side, just in front of the plastic wheel arch cover. I followed the drivers side one and it meets up with the headlight cables and horn and is fed back through the firewall.
I read on a couple of other threads that by default the front fogs won't work and require a new indicator stalk so that they can be operated independently of the rear one. Is this the case? Can I just buy the fog light inserts and have them working?
Any help appreciated.
UPDATE:
Remembered to link the photos this time...
UPDATE:
