Apexi SAFC Wiring diagram
Titch
Micra K11ng
Right - well it came through the post today, so now need help to know what the wires mean and where they go.
Have 10 wires in total.
Red - Positive
Black - Ground
Brown - Ground (closer the ECU)
Green - ???
Pink - ???
Grey - ???
Blue - ???
White - ???
Yellow - ???
Orange - ???
Cheers :)
Right worked out:
Red - Positive
Black - Ground
Green - Rev signal
Pink - Not used
Grey - Throttle postition
Blue - Not used
White - MAF
Yellow - MAF
Orange - Not used
So - have got all of these in, and then when i get passed 3000 revs, i get no futher. So i dissconet the ones that are at the MAF, and its fine. So at the moment, it works, but have no Air/fuel sensors. So help peeps!
Chie - post a pic of where yours is wired mate!!
Yea - the yellow and white. But when these are connected it won't rev past 3000. That was the problem. Have spoken to Chie, and had a word with George also, and got a few things to try. Anyone got a Full wiring diagram of the Cg10/13 ECU's? as they are both the same :)
Titch :kungfu:
Done it! Right - works perfectly :) So impressed with the results.
Runs sooooo smooth its unreal, ides at 506 rpm perfectly, and 80 in 5th is at 2400 revs!!
need to play about with it some more as can't get into the powerband atall with it, but will work it out soon.
Will also post up a wiring diagram as its actually really easy.
Titch
