P
panther_512
Hello to everyone!
My boss gave me a Nissan Micra (March) automatic. The engine is K10.
I love this car, but I am concerned about it's engine.
This is the story:
The car had 120.000 klms. There is no Super (leaded) gasoline here, so I put Unleaded 98 octanes.
I drive every day about 150 kms at speed of 120KMs/h to go to my work. The car behaved very nicely.
After 20.000 kms, the engine started having some small problems:
1) Oil leakage. It started loosing engine oils and gearbox oils (the big cap of the gearbox always has oil around it)
2) The automatic gearbox changes the gears with difficulty.
3) The performance of the engine dropped significantly.
So, one day the engine blew, because the fan stopped working. And we changed the engine with a new one (same K10) that had only 30.000 kms.
At first the engine was at top performance.
I have driven only 20.000 kms with the new one and again the engine started having the same problems.
what is the problem? The gas (Unleaded)? Perhaps I drive too fast for this engine? But the engine when it was at top shape could reach speeds of 160KMs/h. So 120 should be good.
To give the engine back it's lost performance, I used this oil (you put it inside a full tank) that cleans the fuel system. I saw major improvement, but it lasted only for a month. After that, again the performance dropped and while at first I was just touching the gas pedal to reach a 120KMs/h speed, now I have to push the pedal with medium-to-strong force to make the car reach that speed. :k10:
Accelaration has decreased and top speed has been reduced from 160KMs/h to 140.
Any advice?
This is the story:
Any advice?
