They do not mix that is at least what I was told. You have to use new. I'm guessing here that you will likely use a different type that's already in the system.
(As Mika described drain the whole system if possible plain water)
(don't mix)
... When mixed together they can form a thick, jelly-like substance that can completely stop all coolant flow which can lead to overheating.
Sent from my ASUS_T00P using
Micra Sports Club mobile app
