Anti Roll bar
Mat.T
I've just just fitted the rear anti roll bar as found on 1.2 K10's to my LS i was surprised how much difference it has made, no roll what so ever (the car is also lowered and on gas shocks) well recomended cheap mod :slm:
guide to follow.
it came from Umars K10 Turbo, i think that the ur 1.2 GS would have one as standard, if not your local srappies should have one :D
no, it goes between the rear trailing arms. All 1.2s have them. THey can also be added to any pre facelift 1.0 excelt the 83-84 datsun type ones because they hade circular trailing arms.
Damnit, mines a facelift!
So is mine, mine has the 1.2 links/trailing arms fitted after my little crash :D
if you went to a scappys you could get the bar and the links at the same time and swap them all over :)
well yes, the links can be a bugger to remove, especially if you are up to your ears in mud in ur local scrappies, but if you have a nice warm garage and a few hours its quite easy :)
