Am i being paranoid or is there a problem?
Tonight i parked at my local tesco and as i was walking in i looked a t my micra to find it lower on the right hand side i had noticed this before but i thought it was the way the roads were but now i know for definate its lower on the back right and front than the left? its lowered on Pi 35mm Springs that i only had from christmas i noticed this as soon as i put my 13inch wheels on i checked the tires etc but its not them it i measured it it is lower but a good few mm on the right is it my panhard rod? or should i not panic? :/ my heads messed thinking about it :p, also a pothole got the lip of one of my wheels yesterday... b*****d :(
mine was the same too, when i lowered the bottom spring perches i had to raise the offside one back up 10mm to level the car out.
its probably due to the engine weight and steering column and support assy eh
thanks man! :) peace of mind then lol, how did you raise her man? or were you on cuts/different setup?
matiz legs krisism, 3rd one down
