Almera Airfilterbox Fitment
Ok, i finally got hold of an Almera Airfilter box but the Carbon box is in the way, what mods do i have to do to alter the carbon box to clear the airfilter box?
J
J
I just unbolted it and let it-hang loose in the engine bay, its sits on top the of the gearbox. Had it like it for a year no problems at all.(Y)
lool, id rather bolt it somewhere steady Eliot.... i thought maybe the bracket needs to be modified, not sure the easiest way e.t.c.
J
If I new what to do with tubes I'd bin mine
When I fitted the last engine it idled funny, the a team managed to fix the problem which was one of the carbon tubes was fitted funny,??
Frank diagram please good sir :)
:grinning:
there are 2 thin vacuum pipes to the inlet mani (1 for the fuelrail f/p/r, which you leave on, and 1 at the back below the t/b, which you blank off)
then there are 2 bigger vacuum pipes (1 for the brake servo, and 1 for the crankcase breather, you leave those on)
any other vacuum pipes are excess to requirements :grinning:
Hi frank, so what is the carbon box for, what purpose does it serve the engine and also by disconnecting it how would the engine run??
Cheers!!
J
