If i had a set of 15 inch alloys, with an offset of 45 - would they scrub REALLY bad?
... or is that just on full lock etc.. they would be 7 inches wide, but with a thinner tyre like 195/45/15s...
(Also, the offset should be 35, so since they are 45, does that mean they will sit 1cm closer to the inside of the car (which is where i can imagine them rubbing) than the same set with an offset of 35?)
