alloys enqiry
pritz
Site Supporter
hey i would like to know whether alloys off a mazda 323f 1996 4 stud would fit on to a nissan micra k11? ive checked the differences and the only difference is the bore does this matter ?
(Y)(Y):grinning::grinning:You need to check the PCD for the studs, the spiggot ring diameter coz the ring on the hub can be wider on some cars and the rims with smaller spiggot rings wont fit unless they are aftermarket wheels with a plastic ring adaptor which you can pull out and fit the correct ones, and finally the offset of the rims.:p:p:laugh::laugh:
You don't want to wreck the new wheels/tyres on fouling the bodywork:(:(
Either bore the centres out or lenghten the studs and use spacers, there are loads of wheels that will fit a micra- toyota, vauxhall, renault, vw, honda i think its just ford and peugeot that dont i have golf gti wheels on mine!
