CMF_Peter Felix
» CMF MemberAfter finally getting the car started yesterday while going for a test run, I discovered the Airconditioner was not working. Since it was working before the car konked out, I then checked the AC relay in the fusebox near the battery and also, the AC fuse in the dashboard near the steering wheel - both are OK. Could anyone please advice if there is any other fuse or relay located anywhere else that I need to check? Secondly, in the fusebox near the steering wheel, there are three 'blue' colored relays none of these are mentioned on the fusebox cover - does anyone know what these are for?
Thanks in advance to all for any help.
Regards,
Peter
Karachi
Regards,
Peter
Karachi
