I've got a 54 plate Micra 1.2SE that's just started flashing the airbag warning light. The dash computer also occasionally says "Airbag warning, please see Nissan Dealer".
I've tried the ignition trick where you turn the key in certain ways and I can put it in diagnostic mode but the light just then flashes one long flash then a few short flashes. I've also checked the connectors under the seat and reconnected them / cleaned with WD40. There's 2 connectors under the drivers seat which I've done. The passenger seat only has 1 connector connected, the white one isn't. There's nowhere I can see for it to go but the seat has the lift up compartment storage so I'm assuming it's meant to be like that?
Fuse has also been checked.
Any ideas where to go from here? Anything else before getting it checked? If I need to go to a garage, should I go to a Nissan one or any recommendations in the West Yorkshire area?
Thanks!
Thanks!
