A few times now my
Airbag warning light has started flashing <_<
The first time it happened, of course, I panicked, and took her to Nissan...and was £30 lighter 15 minutes later
anyway I later discovered a resetting trick on another Nissan forum...as follows:
First turn off the radio and switch the ignition off.
Then…
1. Turn the ignition from off to on.
2. The airbag warning light will stay on for approx 7 seconds, as soon as it goes off (within 1 sec) turn off ignition.
3. Wait for more than 3 seconds.
4. Repeat steps 1- 3 two more times.
5. Turn ignition switch back on again.
Now turn off the ignition for at least one second and then back on.
This should now have reset the light. If the light comes back on again then it would be fair to say that you have an airbag fault.
I found that it took more than 3 goes to reset it, more like 7...
After I'd had it sorted I spoke to the technician and they told me that the loom under the passenger seat is identical in the 3 and 5 door models
...of course the 3 door models seats move forward, unlike the 5 door's seats that don't need to
...so this wire is not
really long enough... <_<
Now when I need to put something on the back seat I either slide forward the drivers seat or just
tilt the passenger one
