Airbag flashing! yellow wire disconnect
Hello everyone!
need help
I have a nissan micra k11 1999 1.3 gx version Blues
the next day to leave the house the airbag light started flashing.
Never happened, immediately I went looking on the internet about it and seen many solutions turn out the light, but none worked.
I began to suspect, and went to see the airbag and repair driver's side wires on a yellow cord unplugged, but I can not find place to connect! I do not have that airbag? or when I bought the car (will about a year) not already had.
Is there any way to turn off the light without being connected to that airbag?
thank you all!
***Airbag Resetting Procedure***
If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Here is how to reset it:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again.
