air/fule ratio meter?
Well before you get into ordering EMS equipment, have you managed to get the car started and idling properly on it's current setup?
It's rare that I give out information on this forum, but I don't want to see you procure lots of equipment and find it to be of no use to you.
The reason I ask is, the airflow sensor that you took from an existing throttlebody is liable to be out of calibration due to the airtube being cut off. As a result the VQ map that the standard ecu is programmed with to match, which will be the base you will be adjusting off, may not be reliable and I am doubtful that it will give a reliable VQ v's RPM for mapping purposes.
right, so should i get a new one and dont remove any of the air tube?
what should i do about the fuleing?
and thanks for the help mate!
