Air flow mass sensor
I have been having a lot of trouble with my k12 micra on start up, the revs bounce up and down sometimes causing it to cut out. I have changed the ignition coils, spark plugs, and cleaned the throttle body and I am waiting for a new throttle body to arrive. the only other things left are the air mass sensor or if this doesn't fix it the ECU :down:
Does anyone know where I can get an air mass sensor from with the details:
22365-ax000
siemens
5WK96819
germany
>PBT-GF30<
When I needed one for my Primera, the cheapest place turned out to be Bennetts. Might be worth contacting your local branch - if they don't stock it, they can get it in.
Have you got a OBD_II codes reader to see if there are any codes ? They are £25 on ebay and cheaper than replacing an AFM unnecessarily
