air con removal
CMF_justin
Just wondering if anyone has done this if so how. Its empty of gas from motor changeover only wanna take off part attached to motor. Rest is gone so pod filter could sit there. Do I just fit a belt from micra without air con after I remove part or not that simple. Any help greatly appreciated
CMF_Danvillan
I believe you will have to get a new bracket for the alternator, as it has to be moved from the top to the lower bracket to fit the new belt. There is a different bracket for just an alternator only, you should be able to get one from a wreckers.
