CMF_1300cc
» CMF Memberi have already replaced the bottom engine mount, engine idles quieter but still getting this knocking sound when accelerating hard, what else can it be?
just want to make sure if we're talking the same part, can you tell which is the upper mount by referring to this site http://nissan4u.com/parts/micra/er_..._mechanical/engine_and_transmission_mounting/frank2 WROTE:
"upper mount not sitting central ? (i had to fit some packing on the rear mount on my blue car to get an equal airgap on the sides of the upper mount, for some reason)
thanks frank2, ill check it againfrank2 WROTE:
"maybe the extractors are pulling against one of the mounts eh, and the engine tries to rotate "top backwards" and "bottom forwards" ,if you want to check for clearance under load
1300cc WROTE:
"is it normal for gear stick to moved after releasing the clutch then accelerate?
did your suggestion today, and no more knocking noise.....thanksD.K.C WROTE:
"Space your swaybar with some steel plates under the central mounts.
Same problem happened to me.
