Can you not put your old speedo in the new cluster, or are they different sizes?
Thanks!You need to get under the centre console and add a link wire between the ECU and the next conection block on the loom. Its about 8" of wire missing between two plugs. I've had to do it on mine (L) to get the super s cluster working. Mine is just a link wire forced into the empty plug socket, and held in place with blu-tac! (and I call myself an engineering teacher!)
Here's some help:
http://www.micra.org.uk/threads/k11-pre-facelift-rev-counter-wiring-procedures.40661/
http://micra.proboards.com/index.cgi?board=guides&action=display&thread=30
Thanks!
Gave up with the dizzy as it's far too cold to be outside, brrrrrr.
Best way to get under the dash?
Remove plastics, contort over backwards with the gear leaver and hand brake diging into you, etc.
The red wire is the one I added
Yep, plug 2 in the ECU is blank so I guess I'll run a wire from there up to the dial plug.Bums. Your's is a fair bit later than mine, prehaps they deleted them to save some money. Oh well, you will still have the empty socket on the ecu plug, you may have to take a wire all the way up to the plug on the clock set. I might be a bit like Seb's problems in the second link I posted.
