Hi again all,
Just a quick one - hopefully easy to fix. I've noticed the accelerator pedal sticks in position (non-depressed) sometimes, and is nearly always stuck in position when I go to drive to work in the morning
It then requires a bit of pressure to un-stick it, and all is well, for about 10 minutes then I'll notice the same again. It's not a problem for me, as I know only to press it in a little way to unstick it and then it's fine, but the missus tends to give it a bit too much pressure and ends up overrevving it, then cursing the poor car
I don't want to hurt its delicate feelings so if anyone could tell me where to look for the source of this problem and where to fix it I'd be very grateful - I would guess it's just some sticky crud built up somewhere which causes it to lock in position when left in place for a while. But I haven't the foggiest of where to look
Any help much appreciated
Jim and Micra
Jim and Micra
