CMF_Pierce
» CMF MemberHey guys,
Got a bit of a problem with the green micra.
In 2nd(especially 2nd which concerns me), 3rd or 4th gear if I'm going at a speed that runs the engine at 2 thousand RPM or lower (so a comfortable cruising speed, easy on the fuel) and I put my foot down all the way to accelerate fast... instead of a smooth acceleration (which has always been the case until now) into 4k or more RPM I get this stuttering RPM lift that feels like the engine is being choked and the rear muffler lets out exhaust in spurts like a slow drum roll.
I think Ive had this problem before, which ended up having the engine stall in neutral, turned out to be throttlebody failure. Only 4 days ago I degreased my engine bay heavily. If this is the throttle body is there something on it I should hit with WD40? Perhaps a spring or something exterior on it is seizing?
Fault Checks ran so far:
I know that I didn't get water or degreaser in any internal areas.
I have checked my exhaust and headers extensively, no rust holes.
Any help is appreciated
