Abs? will the abs light come on if the abs pump is bad
Hi I took my 2000 k11 1.4 se+ with only 31.000 on the clock in to ats euromaster because it was pulling to the left and they told me my brakes were binding on the left side and it was the abs pump and the tracking was out which that’s why it’s pulling! but the abs light is not on the light come on when I start the car then go’s off. But I jack the car up and the drives side is binding more I know I need to clean and grease the slide pins! So what I’m asking is will the abs light come on if the abs pump is bad?
Its a euromaster. They dont have a good reputation here in Netherlands.
Id clean and grease the brakes first. And if they are really bad refurb them. That would most likely solve the problem. Also do a good brake fluid flush and fill up with some fresh fluid.
Thanks ??
