Hi guys.
I needed to buy a new set of brake rotors for my k11. When I was searching for brake rotors I saw that are two types of rotors, one for cars with ABS and other for car without ABS. I ended up buying a non ABS rotor, since my car don't have ABS.
Does anyone know if a brake rotor for an ABS car can fit in a non ABS car? Knowing that an ABS rotor is slightly bigger than a non ABS. In the k11 case the ABS rotor is 4mm bigger in diameter and 6 mm thicker.
Best Regards.
Best Regards.
