Abs light
Brill thanks. Will have a look tomorrow. The replacement drum needs new bearing,was half debating whether to wait and jus get all seen to one time,but its brakes,cant be too careful with them eh!
Most new drums come without the abs ring that pushes on around where the bearing is on the inside. Did you swap the abs ring over ( sorry for stating the obvious but it's not a toothed ring like on a passive abs, its a smooth ring as its active abs sensors)
