Howye....I love my little 1.0 K11, but I want a project & she could do with power!
So I'm gonna find a CG13 here somewhere and turbo it The CG13 seems to be a lot harder to come by here in Ireland but there's bound to be one somewhere.
I need your guys help putting together a shoppering list!
I'm thinking GT15...I'd like a nice juicy midrange...I have a bike for 19k N/A Screaming!
Am I right in saying the standard 9.5:1 CR is good for 10psi boost & with an IC can get around 130bhp?
So Far I'm at:
Almera / SR20 / bigger than stock injectors
Adjustable FPR? Fixed or Rising Rate ?
Wideband Lambda ?
Turbo Itself
Oil Lines
Inlet Piping
Modify Exhaust Mani (Or Frank do you sell em?) and make downtube
Aaaand I'll need an ECU (Nistune Type 4?) and Engine bay loom (I've a dizzy at the moment)
I'm considering making a simple Arduino ECU but that's another project altogether!
Does the K11 AFM need to be changed to a bigger one?
Does the fuel pressure regulator have to be rising rate? Or is this just if the ECU is left stock adn the pressure is increased to prevent leaning out?
So Far I'm at:
Wideband Lambda ?
Turbo Itself
Oil Lines
Inlet Piping
