A few K10 bits and bobs
Mat.T
Set of 4 Super S wheel trims, with a few scratches and scrapes ok condition: £20
GSX/Super S digital clock with grey surround: £10 inc p+p
GSX center console sprayed black: £15 inc p+p
2 x Upper Rear suspension links fitted with all new bushes: £20
TIM 52mm voltmeter with holder: £20
Set of K11 steelies still in boxes unsued, valves fitted: offers
I am open to offer on all these things, sooo make me an offer :D
Hey
Interested in the dials can you post a pic is it the actual dial cluster or just a part of it? put me down as a very likely if it's a dial cluster and a maybe if not but def need a pic!!!
Cheers Dave
does the digital clock work?
it did when it was taken out of the car it was in, i have no reason to suspect it won't work now, as its just been sat on a shelf
dials? if you are refering to the volt meter it is an aftermarket gauge.
can you post up a picture of the digital clock so i can make sure it the same as the one i have
im sure its the same but i just wanna make sure
