Hi guys,
Sorry if my question is too stupid to you. My Micra needs change of the following: both drive shaft joints (is it called CV joints?), both joint rods and both front brake discs. I live in Norway and I will order the parts from ebay.de as it is much cheaper there.
I believe my car is not ABS, am I right? This is important for drive shaft joints, correct?
I am thinking to order these: 2x http://www.ebay.de/itm/ANTRIEBSGELENK-GELENK-ANTRIEBSWELLE-NISSAN-MICRA-K11-10-/230380618358?pt=DE_Autoteile&fits=Make%3ANissan%7CModel%3AMicra%20II&hash=item35a3c14276&_uhb=1#ht_3035wt_952
http://www.ebay.de/itm/140786043593#ht_5431wt_1186
http://www.ebay.de/itm/NISSAN-MICRA-K11-BREMSSCHEIBEN-BREMSEN-BELAGE-VORNE-1-/380465522129?pt=DE_Autoteile&hash=item58958325d1&_uhb=1#ht_2374wt_1139
I am not sure with the discs. There are some with 5 holes and other with 4 on it. Which one is right, should I dismantle tyre and check? I have 4 bolts that are keeping the tyre in its place, does that mean that I need the discs with 4 holes?
