6 by 9s again
A
albruno
well i swapped the front speakers no trouble just using the existing speaker wires from the old ones however there are no speakers in the rear factory fited so how do i wire the 6 by 9s do i need to buy a wiring kit?
Just wire the 6x9's to the rear speaker outputs of your HU. Will require you lifting some carpet and trim to lay the cable to the rear.
No need for wiring kit, if you're not using an amp, will just need some speaker cable, would recommend you use something more than 13strand bell wire though.
Anything else, just ask.
Just thought you may want some spade connectors for the 6x9's, to go from the cable to the speakers.
