5-door K11 body kit.
I'm seen alot of body kits on the web for 3-door k11. I have a 5-door K11 and was wondering if anyone would know where i can find a body kit for a 5-door? I know the front and back bumper should be know problem, I'm just concern about the side skirts. Is there a website or some type of modification i can do to the sideskirts? Thank you.
You would probably be able to fit a 3 door kit without any problems, as i can't see why the skirts (depending on type) would overlap the doors. If they did, just cut the skirt where the door needs to open and bolt one part to the car, and one to the door. Will line up perfectly when the door is closed :)
i've seen it done on a K10 once.
My K11 Bodykit was designed for the 5 door. I had to cut the lip down which sits beneath the doors.
The opposite of this wouldn't be that much tougher! If you were having the side skirts smoothed in this wouldn't be a problem anyway.
