in what way ?45 degrees is just easier and cheaper to manufacture....
will link a video by tony vizard explaining how gains work later, seal is harder to create with 30 degree so is more laborious to get right which is where extra cost comes from
Ok fair enough, just looking to try something a little different to the standard GA airbox and tubular manifold. I agree, I sat through the whole 2 hours of David on youtube without a break! It's pretty heavy stuff if you've not got a pretty solid grasp of how engines work and perform already, but its all genius.
What size followers does the CG use as standard then, and what work is required? I'm great with pushrod engines, overhead cam engines i'm still learning.
