Hi you should look for these on ebay.
They are also the none painted ones available.
You should avoid cheap ones that are not up to standard.
These are 20mm and come with 8 bolts.
Mine are installed at the rear.
Do not what ever you do get the none billet alloy ones as those can shatter or break easy.
Search for hub centric wheel spacers 20 mm
Company is watfieldslimited
I picked these
Pair 4x100 Hubcentric Spacers 20mm Wide 60.1CB 8 Wheel Bolts CLIO BLACK UK Made..
Different options available so look up the seller name.
Other good brands are bimecc and direnza.
Avoid none hub centric this is important.
Sent from my ASUS_T00P using
Micra Sports Club mobile app
