2012 k11 class 1 junior autograss.
Hi
I will soon be starting to build a k11 micra for my son to start autograss racing.
Is there any one on here that could tell me how to wire it up??? All the lights, clocks heaters ect will be removed so all i need is for it to start and run, charge the battery and maybe a temp guage but thats not essential.
the engine/ecu loom is separate to the main loom iirc rybolt, tho i guess you will have to wire in the fuelpump relay and ignition switch ?
has the car got NATS fitted ?
yes i will need the fuel pump. as for the ignition switch.. i would normaly replace with an on-off toggle switch and the starter will be a push button.
sorry av no idea what nats are!!! if its anti theft then am unsure.
Write your reply...
