2 ways to turbo
Hey everyone.
Now I know the k11 can run the 33 gtst fuel pump n sr20 fuel rail n injectors (With some minor changes) but then will the standard computer be able to handle boost with those modifications? Or is simlpy adding a 5th injector n injector controller better there for having some kind of engine managment without spend big on a after marcket ecu.
CMF_frank2
it probably depends how much boost you intend to run matthew, one dutch member on here ran his for 3 yrs iirc with a boost trigered 5th injector.
i think the stock spark curve will make it very laggy tho
frank
