1998 K11 bits needed
Hi all,
My first Micra (1.3 GX) finally died and had to go and 'live on a farm'.
I have now acquired a 1.0GX which I am getting roadworthy to teach my 2nd daughter to drive - it is a late 1998 model with the later style headlights.
On inspection, I will be needing the following parts :
1. Drivers side electric window mechanism along with the plastic bits that clamp onto the window glass
2. Coolant expansion tank
3. Blaupunkt to euro/DIN car stereo cable adaptor (Blaupunkt has 2 connectors, one 10way and one 6way)
If anyone can help me out or point me in the direction of someone who can, I would be greatly appreciative.
Graeme
If the coolant tank is cracked/holed on the top top its an easy repair with Glass fibre matting and resin.
Breakers would be the place to get window clips or as said they can be reglued onto the window with Rhino glue .... plenty on, wind the window up tight and leave overnight :)
Connectors on the leccy windows in the doors can be a bit dicky so check them first before spending your hard earned :)
Write your reply...
