1998 1.3 swap K11 ecu issues, tried numerous fix's
Having nats k11 issues, Red key chip 1998 flashing engine light, changed pillar nats box and got matching ecu and key present, same problem, ive got strong spark across all four cylinders and fuel at the rail but no luck still stuck with the flashing engine light.
I've seen on older posts Fusion motorsport ed made custom ecus which I tried to replicate, had no flashing lights but still no start.
Feeling very stuck with this atm Before 1.3 swap car was spot on, 1.3 swap lasted about 3 months then started to feel like a crank sensor going wrong (micra hasn't got one if I'm correct) then lead to this problem,
If anyone has any help would be much appreciated cheers.
Write your reply...
