that would be handy. phone call made.. 180mm = 48.99 190mm = 62.99 . they have the 160mm one too they say.. statement was "friction plate is 190mm"
how long ago you got yours?
Thats the exact clutch kit im using il have a measure when i get home .....
with the right pressure plate it should eh, the little 160mm 1.0 pressure plate is 170mm o/d, and with a bit of fettling you can get a doctored 180mm friction plate under itI will be needing a clutch for the Micra-T soon.
Im assuming the 190mm doesnt "fit" straight" on?
ayethis says its a kit so included
