15" width and offset
How guys, I'm getting a set of 15" wheels to get 195 semi-slicks.
What kinda of width (6j 6.5j or 7j) do you recommend running without wheel poking out of the body?
Also, do you think a 7j with a set of 32 will poke out?
This is the comparison between 165/60 r14 5.5j standart wheels, vs 195/45 r15 7j 32et, there's a lot of difference...
Enviado do meu MI 8 através do Tapatalk
I run 195/50/15 on 15 x 6.5J x ET40, with an 8mm rear spacer (made from old brake disc), dropped 50mm, 2deg front camber
my front rim sits flush to the arch (rears needed 8mm spacer to make em flush too) and doesn't rub at full lock or full bump but I've removed the plastic inner guard.
fronts at 6.5xet40 doesn't need spacer.
7" x et32 imo is abit too wide as shown in ur graphic.
the inside lip is 5mm wider than mine (which may rub the chassis)
and the outer lip is 20mm wider than mine (which will probably foul the arch lip & arch lining at full lock)
the ride height and bump stop setup will also have an affect.
