1.6 thottle body and fueling
59 bhp is more than enough
Deactivated Account
right i have a full manifold and exhaust and i also have a adjustable fuel pressure regulator just sat in my garage not doing very much so i thought while im getting it on the rolling road i might as well try and get the fueling somewhere near. if i put the 1.6 throttle body on before hand could i still get the fueling about right with the afr?
with the FSE you can get it idling better, but that doesn't increase the amount of fuel injected that's still controlled by your injectors and ECU. All it does is increase fuel pressure in a shorter time.
I'd suspect it would continue to overfuel. Just get it mapped.....
As above will see you a very noticable increase in torque, and power top end..
not a turbo... but with the mods you listed saw me a little powerful engine
