1.6 TB & Non NATS ECU
Titch
Micra K11ng
Got a primera 1.6 TB and Non NATS ECU for sale.
Make a huge diffence to the CG13, not sure about CG10.
Will need modded to fit, but its not that hard! Will show you how.
£60 all in + postage.
so noob!
it's the bit that allows air into the reaction, the more you press accelerater the more it opens to let air in.
It's under that big black fliter box.
Am sure someone here can get a lot more technical if you need
Ok - its the part that sits on top of the inlet Manifold. It alows air to enter the engine. The Throttle Body from the Promera is bigger, and therfore lets more air into the engine giving it a better pull through thr gears etc. You'll need the ecu to match this so the car knows what is happening.
Your car cannot have NATS, or this won't work.
Titch :kungfu:
