So I’ve recently bought a 2nd facelift 1.4S and the gearing is way too long, I have a 1.0 gearbox from a 1st facelift dizzy model and want to know wether it’ll fit? Or what I’ll need to change to make it fit?
I suspect that it should fit right on but I know the drive shafts are thinner than the 1.3 or 1.4 but if you changing the sun gears in the diff to have the fatter drive shaft. The only other thing that may not fit is the gearbox input shaft but I suspect that they would be the same size
