1.4 cga crank position sensor
Would someone be able to post a picture of the crank position sensor on the coil pack engine please. Is it the same config for 1.0 and 1.4?
Cheers.
the cvt one appears to be in a different position btw, 12 o,clock at the top of the g/box, dead opposite tdc, where-as the notch on the manual one is about 20deg btdc :eek:)
http://www.micra.org.uk/attachment.php?attachmentid=13565&stc=1&d=1253449506
http://www.micra.org.uk/attachment.php?attachmentid=13566&stc=1&d=1253449506
is there any chance that one of these flywheels and sensor to go with it would fit a non coilpack? just that it might help me with my ecu problems.
you could mount the pressed steel one onto your f/w ed, and a crank sensor on the bellhousing :cool:
Sorry, what I meant was can somebody take a picture of the crank position sensor in the gearbox please.
Just to add a bit of background, we've got a 1275 with ITBs that we are looking to convert to the cga engine and it woud be nice to be able to get rid of our crank sensor that is mounted on the bottom pulley (a bit like vauxhalls do). Need to see if we can fit it to a gearbox that never had the sensor.
Cheers.
