I know this probably has been done before so can someone point me in the direction of a guide on how to do the 1liter to 1.3 engine swop
cheers
You'll need the engine, gearbox, driveshafts, the brace that goes under the engine, and ideally the ecu.
Which year, I assume you changed the Flywheel and clutch too?
When something on mine breaks, I'm just going to swap the whole running gear over.
wel i have the two car 1.0 1993 and 1.3 1992, im goin to put the 1.3 in the '93, so what parts will i be needing to swop.?
Depends what you want.
The pulleys on the cg10 are lighter, so is the cg10 flywheel.
But, the cg13 gearbox, and driveshafts are lighter and the clutch is bigger.
sorted will the 1liter come out without taking out the gear box and will the 1.3 go in no prob
