1.3 inards inside 1.0 engine
Can hello i need some more information on on putting the 1.3 internals into the 1.0 block. Can anyone help me out please
Which internals? If you put them all in you'll just get a cg13de with a different engine number. A cg13de crank and conrods will make a high compression cg13de, CG13DE pistons on CG10DE crank and rods would lower the compression.
Cg13de cams will help a CG10DE, the heads are the same.
Does that help?
CG10DE conrods are longer and make up for the difference in stroke between the cranks, the CG10DE pistons are flat topped which makes up the difference in compression ratio.
