SuperUno
Buy & Sell Member
CG3 Engine taken from a 1995 K11, done about 120k miles.
Was in the our rally car until last summer, did about 110k miles in a road car before being used in the rally car.
Never used a drop of any fluids, only removed to move to 1.4 and more power.
Has sat in shed, but still turns over fine, no water pump and is muddy! Will need a cam cover.
£50
1.3 Gearbox from same 1995 car, same history but done less rally car work as was removed only due to moving to the 1.0 box for lower final drive. Again never lost any fluid, and g/box oil was changed regularly when used in rally car and came out clean with no bits on sump magnet. Again is rather muddy...
£50
Both collection / delivery from Alyesbury / Uxbridge areas, although i do travel around with work.
£50
£50
